12 mm or 1/2" shank router bits ?
Hi,
I will write in English as my German grammar is very poor - hope you understand me / can write back in German if you like - I understand it very well.
I moved from Australia to Croatia and brought my old Makita 3600BR router with me. This router has separate 12mm and 1/2" collet assemblies i.e. to change from one to the other you need to remove the whole assembly by disassembling the router - as I ofcourse don't want to do this, I need to decide whether I will be using 12mm or 1/2" shank router bits.
Could someone who is experienced with routers comment whether it is better to stay with the 1/2" or 12 mm shank (which router bits are more readily available/larger variety/better priced etc) and any pointers to good sources ?
BR,Vjeko
Re: 12 mm or 1/2" shank router bits ?
Hello Vjeko,
wellcome here,
my 20 years old Makita 3600 NB is able to use 8 and 12mm as well as 3/8 and 1/2" router bits, but I only use mm because these bits are easyer to buy in Germany. So I would prefere the router-bits which are easyer to get. But I don´t understand the Problem with the change of the fixing. This is done in a few minutes, but I don´t change so often, because I have enough routers;o)
Best regards Johannes
Hi Johannes,
I much appreciate your feedback ! - I must talk to Makita
again as I have two separate collet assemblies and not
just collets which you change.
By the sound of it you have a bit of experience with routers,
which larger router would you suggest (I have a small Elu OF 97E
in which I use 8mm bits) ?
Is there a particular brand of router bit you buy/good source ?
BR,Vjeko
Fräser für die Oberfräse
Hallo Vjeko,
diesmal antworte ich in Deutsch, damit alle mitlesen können, falls etwas unklar bleibt, bitte nachfragen.
1. Meine Makita-Oberfräse war von Anfang an recht laut. Dies hat sich geändert als ich die Kugellager gewechselt habe.
2. Ich habe meine Fräser meistens bei meinem Maschinen-Händler gekauft. Es waren ISO, KWB/Leitz, Ghudo, ELU, und Festo, je nachdem wer das passende Profil im Angebot hat.
3. Ich habe auch billige Fräser, und die funktionieren auch. Zumindest wenn man nicht 1000m damit fräsen muß.
4. Es ist sinnvoll verschiedene Fräser für verschiedene Materialien zu nehmen. Wenn man zum Beispiel Birke-MPX fräst, kann man mit diesem Fräser noch viele Meter MPX fräsen, aber wenn man jetzt versucht Erle zu fräsen hinteläßt man schnell ein MPX-ähnliches Brandmuster auf dem Holz.
5. Einen Tip zu einer guten und preiswerten Oberfräse mit 12mm Werkzeugaufnahme kann ich leider nicht geben, da ich Besitzer einer stationären Fräse mit Vorschubapparat bin. Als ich meine Werkstatt noch zum Broterwerb betrieben habe, hatte ich immer 6 -8 Oberfräsen im Einsatz, da es wirtschaftlicher ist als dauernd den Fräser zu wechseln und erneut einstellen zu müssen.
6.Zur Zeit sind die Preise für Handmaschinen in UK(England) sehr attraktiv.
